very nice so far it will be one of the best built r32 s around.![]()
Little Update!
As iv actually be able to do some work! new job has me away from this to much latly! tho i recken ill fight back in the next few days now!
First off HUGE thanks to Roddie at IceTronix sorted the 3 of use out with some nice carbon bonnets n to be fare there spot on!!!!! Recken i was home all of 5 min before it was on the car, sparked me in to life to get this finished.
Above you'll also see the oilcoolers new home between the headlights alot of messing with the pipes to make sure they all ran ok n didnt kink but i got there! recken it evils up the front no end
Also thanks to "JDM" for the RB25 inlet elbow and spark plug cover, and to JoeyMc for letting me use this sand blasting box to get them all shinny n clean again.
Also after fitting the covers i found that the old metel clips that hold the coilpack loom in place had suffered from the heat and have become hard & brittle, so picked off all the plastic and out with the hammer to straighen them and used heat srink to coven them up again, recken they turned out well not a big job but dose tidy up the look of things!
I had asked here but no one answered, Samco ducting hose for AFM to Turbo gona give it a go, but recken it should be spot on for what im after! Now all fitted!! tho kinda hard to see in the pic's below, also thanks to Darren for the Z32 AFM by the way and side mount rail!
I had fitted the GTR injectors, but got alittle ahead of myself, as i didnt wanna start it with it over fueling like fuck with the big injectors and it might wash the bore, dout it would have but ya never know.
So ended up swaping back the old RB20 ones till i get it started and know everything is ok and untill my resistor pack arrives
As much as i love this Plazmaman Inlet! if found a prob ! dipping it for oil is now not so easy!
(yes i did scrach the water hose i had painted dam braded fuel hose! hence the rubber sleve that it wears now)
tho cable tie (is there anything they cant fix) and a rubber band will have to do for now to extend it under the inlet and to make it easy reach,still not easy but ill surrive!
SO after all that i had to put the bumper on again before paint to make sure all is well n have a look what the bonnets dose for it!
Love this pic reminds me of a R31 (taken with the telephoto len, ya need it in my shed is so fucking small!)
So now 2moro i hope to refit the Fcon and ECU, rob a battery from somewhere! (its in the boot now) and turn it over n hope and pray for oil pressure! LOL
Christ thats serious, serious mood for another 32 with all these threads!!!!
thanks alot of Time and effort has gone into it! Just want it to be right! And yes it seams nice 32's are popping up again recken it's about time too
Not sure about power tho should put out a nice figure I hope, built it strong, tho tuby ant huge so won't be laggy n should be nice motor to take abuse!!
nice buildbest of look with it
