As above im looking for the oem part number for a waterpump for a SR20DET redtop out of a s13 silvia.
Cheers
Cheers
No...........
(sorry coulcn't resist.)
jeeze where would we be without google
Water pump 21010-52F00, 21010-53J00
found two different ones the first one had in brackets for all sr20s. why dont you just go to a nissan garage?
I will get the part number this evening if I think of it I have the box for one in the garage.if your looking for one I have one that only ran about 1k 50euro and it's yours
Instead of starting a new thread.
Im still having issues finding a waterpump for my sr.
The problem is every waterpump i find has the same problem, them match up to the bolt holes but the mounting bores are wrong. On the waterpump on the engine the distance from centre to centre is 60mm, but on the waterpumps iv found they are 50mm and 36mm.
Has anyone else come across this problem before?
Did you try an s14 waterpump?
I got a genuine nissan s14 pump fitted into my old 180sx which was redtop sr20. Didnt fit it myself so dont know how or what was required to make it fit...
Yup tried all the s bodies and I'm getting nowhere
did you try B101052F01
