Results 1 to 6 of 6
Thread: Help with s14a
    Sep 2010
    Default Help with s14a
    I think I'm after getting a hairline fracture in my manifold, It sounds very tractor-ie around that area...
    Is there anything else I should look at before I go stripping it.
    & If thats the problem would I be better off replacing it or would a weld do the job...
    Thanks........
    Oct 2010
    Did u check the gasket between your turbo and manifold?
    di Member SIMO's Avatar
    Tipperary
    take a look at the turbo gasket!! make a loud tractor noise when they go too!!! what mani do u have standard cast or s/s?
    di Member barryl's Avatar
    if yer taken the mani of to repairf, its worth replacing the gaskets aswel!
    Team WKD
    Sep 2010
    Cheers!!
    Its a standard manifold,
    Could I upgrade to a S/S one with standard exhaust...
    Dec 2010
    Quote Originally Posted by noel35 View Post
    Cheers!!
    yes u can u can direct fit a s/s manifold
