Results 1 to 8 of 8
    di Member andy t's Avatar
    Are you changing just the diff or the whole unit (diff casing etc)????
    just the diff itself
    Team Twenty !
    SR20 in the front 2way in the back!
    its not low enough!
    Quote Originally Posted by andy t View Post
    "should" b fine then. the casings are a little different for the speedo sensor but the diff itself shud b the same
    was looking at it tonoght & everything seemed to measure up fine apart brom the back plate so just gonna swap that tomorrow & hopefully the rest will bolt together,
    Team Twenty !
    changed da back plate it it went in no bother,
    this can be locked,
    thanks lads,
    Team Twenty !
