Results 1 to 10 of 16
Thread: Wet sanding
    Quote Originally Posted by jake4 View Post
    Can anyone recommend somewhere around the meath area that does wet sanding?
    What are you wet sanding?
    Bucket of water or squidgey bottle..
    drift Republican dR Dan's Avatar
    Cork.
    Bucket of water ( Boil the kettle or the handies will be cold)
    Washing up liquid
    1500- 2000 sandpaper
    Sand away for death
    Not tricky at all...
    And any bodyshop should be able wet...
    Quote Originally Posted by Tekno Twinky View Post
    the whole car... might give it a go just don't want to fuck it up you no.
    Are you re spraying the lancer?
    no just wet sand and a buff or would it need to be laquered
    Cork.
    Is it orange peely or dirt in the paint or what? If its just dull u wont need to wet sand it... Jst polish the shit outta it... If any of the above then wet sand it and then polish th shit outta it
    just swirl marks and lil scrapes here and there
    give the swirl marks a good hard rub with a cloth with some compound and a bit of spit/water
    If they start to get smaller you'd get them out with compound buffing no need for wet sanding
    another good way to tell is if you wet car where the worst marks are, if they dissapear when wet they will buff out.
    Be very careful if you attempt to sand your lacquer only use 2000 grit sia paper if your inexperienced in body refinishing.
    sand a little with a rubber block and dry off keep doing this checking as you go making sure ya don't go through the lacquer.
    Your better off letting that lad Keith do it for ya if your not confident, go and watch him do the job you'll get the idea for next time, if ya make a balls of it you'll have to fork out for a respray.
    Best of luck with it lad
    not sure, but a wet sand will delete any gloss in the paint!
    Just buy or rent out a buffer or get a detailer to buff it for you..
    kinda thing youd wanto know what your doing and will need a buffer just flatten the area not too much and go through with 2000 wet paper then use a rough compound fast cut g3 etc and a fine glaze after that and regular polish after but again youd want some1 who knows what there doing any bodyshop or valeters even should acomadate you no problem
