Results 1 to 10 of 15
    Exclamation needed asap..!!!
    alri lads i was havin me diff fitted today an we relised the cog at the bottom off the casing were the prop connects is all shearded..
    i need dis cog big time lads any1 no were or who i can get 1 off
    what diff is it?
    mines away getting done at the min aswell lad, it was my bearing that went, they hav to be pressed out aswell so it might be a tricky job bt then again i know nowt lol and sorry i dont hav the name of the lad thats doing it hes down in tullamore
    cusco 2 way ste
    the cog im after is the 1 that spins wit he main diff teeth if yas get me?
    its hard to explain coz im not sure of the name.. but when ya have the casing open and you can see the main part off the diff its down behind that near were the prop joins the casing and the teeth off it slot in wit the main part of the diffs teeth...
    its the gear that the prop shaft turns to turn the diff itself ya mean??
    pinion is the word your looking for
    yeah man dats the 1..
    so i need the pinnion so..?? does any1 no wer id get 1
    genuine nissan id imagine, and you might aswell get the bearings too (if the done come with the pinion), as i said they need to be pressed out and diff casing stripped to get access to them, so you will need to reset the back lash on your diff when its re-fitted
    Quote Originally Posted by s15_spec_r View Post
    cheers man i get ya.. wat do ya mean by back lash do i dont understand
    if you hav he car on a lift you will be able to move the prop shaft a certain amount before the back wheels will start to move, that bit of play is the backlash, and if thats not reset the way it should be it could make a mince of your diff, just incase you where gonna try the job yourself just give yeah the heads up
