Results 1 to 10 of 13
    di Member NIALL JZX's Avatar
    tipp
    Default what exact model turbo is this ?? sr20 det
    have this turbo jus wanna find out what model it is if possible...
    heres pics
    and heres what it says on it.. badge etc...
    was told its a hks gtss turbo when buying.. lookin at badge it seems to say 2560..
    how do i no for sure..
    seen this when googled would it be right ?
    Garrett GT-2560R variant = HKS GT-SS
    same turbo as what i have here.i tried a few companies owen developments turbo dynamics and they didn't know what it was if its any help a 2871 part number is the same except the last digit is 5 instead of 4 way2fast4u has the same turbo but hasn't fitted it yet either
    hope that helps you a bit niall
    tipp
    sound man, put it up on dw too, everyone has a different opinion...
    garrett say the diffeence in the 4 & 5 is that the one ending in 4 (472560-14) came from factory with a actuator and the 5(472560-15) came without actuator..
    Quote Originally Posted by DRIFTER View Post
    you have a pm
    id say its a gtss lad but if it was hks it should have a adjustable actuator on it? any way is there any play in it if not how much???
    the GTSS i had one the silvia when i had it 1st had the same on the plate so thats what id be saying it is
    tipp
    Quote Originally Posted by mike g View Post
    cheers lads
    it came without an actuator on it, but thats the actuator off a s15 turbo i had on the car before....
    as per pm its a 2860r
    its a gt2860r as tweek said above their rated for 330bhp!...i emailed garret bout mine before cos i couldn figure out exactly wat it was an thought it was a gt2871r cos of they listins for the codes they have on their site
    tipp
    cheers sound lad...
    @tj thanks
