Results 1 to 10 of 11
    Default Sr20det boost leak??
    well lads, fitted new intercooler (autobahn) and car is,nt runnin 100%. it stalls for about 2 seconds whwn changing gears, nearly sure it's boost leak, all pipes are fully tightned, any ideas what else it could be or any way of checkin????cheers
    You got a dumpvalve?
    ya man have feelin it faulty too
    are you 110% sure you have the pipe for the idel valve conected?? on a vvt engine it will come of the bottom of the intercooler pipe just befor the trotle body, and on a none vvt 180 engine it comes off to the engine side of the pipe just befor the trotle body,
    Quote Originally Posted by mcdae86 View Post
    Take off the dump valve and block it off and try it..
    di Member gary g's Avatar
    ya lose the dump valve the sound of wastegate is way better anyway
    Quote Originally Posted by gary g View Post
    wastegates dont make any sound. unless its an external one with a screamer
    di Member thedaggsy's Avatar
    Aug 2010
    Carlow 0857542948
    have an autobhann intercooler meself , the only rubber that used to leak was the one goin into the throttle body.... hairspray on the pipes when fittin the rubbers and decent clamps.. i'd agree with loosing the bov and maybe if that dosnt sort it start the process of elimination
    hairspray never heard of that before wot dose that do
    di Member conor's Avatar
    Castlebar co.Mayo
    hks eids
    and it will idle fine
