Results 1 to 10 of 11
Thread: Engine Bay
    I Rustle Jimmies twin-cam85's Avatar
    Default Engine Bay
    well want to try tidy up the engine bay in my s14 a bit..so whats not needed that i can take out can any1 tell me??
    If It Aint Rubin, It Aint Low Enough
    BUMP any1
    take engine out hve laoads of room then will look nice and tidy
    nAh wat kinda car is it?
    Quote Originally Posted by ian g sr20 View Post
    S14.....said it in his original post....http://www.specsavers.ie/
    air con ,charcole cannister,
    Quote Originally Posted by damodeane View Post
    sound bump surely more can remove??
    now your talking ill do the flintstones job on it
    Quote Originally Posted by twin-cam85 View Post
    What damodean said and Abs, battery, possible fuse box anything else and you wount drive anywhere..
    im in the process of doing this at the min, have stripped everything out of the bay, meaning all wiring, fuses, battery, expansion tank, etc etc
    basically all i will be left with is the engine, brake master and clutch master, and wiper motor, ive sealed up all holes in bulk head and am now at the stage of rewiring. for that im basically putting all looms and fuse boxes inside the car behind the dash and then just running the wires for the lights and fan up under the front wings so its all hidden, then running the wires to the engine from a new hole i made beside the clutch peddle and heater box, wires come out at intake side behind the manafold so again all hidden
    Low and Slow
    Quote Originally Posted by chrisb View Post
    That sounds interesting, have you got any pics you could post up?
    I've taken out the air-con and a few other bits on mine but i'd like to do a proper job on it.
