Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
  1. #11
    is your hydro open or closed (pulled) when trying to bleed?
    I pump pedel till litle pressure open nipple pull hydro close nipple let off hydro let off pedal..
  2. #12
    Member
    Quote Originally Posted by Bobbys14 View Post
    try bleeding the back brakes using the hydro
  3. #13
    di Member GTSr32's Avatar
    Right! This is a long shot! But iv seen this before!!!!
    Have u put the rear calipers on the right side
    I.E. Right caliper on the right side LOL
    They fit on the wrong side before any ones asks and this leaves the bleed nipple to low so you can't get all the air out
  4. #14
    The hydro only?
  5. #15
    Pull the hydro tight, dont bleed the hydro until you have a good pedal on the foot brake. Bleed 1 at a time, Should work
  6. #16
    No point, he needs to get a good foot brake pedal before you start bleeding the hydro. As i said, pull the hydro, and bleed the brakes with the foot brake as normal as if the hydro was never there, then when your happy with the foot brake, then bleed the hydro.
  7. #17
    Quote Originally Posted by GTSr32 View Post
    No chris didn't do this checked the calipers first nipple is on the top..
  8. #18
    Dont get ya, pull hydro and pump pedal till pressure then what ya mean bleed the hydro?
  9. #19
    Bleeding the back brakes with the hybro won't make a differance....! Are the 2 lines going into each caliper at the back the same lenght....! You bleed the m/c by just opening 1 of the lines going into it....!
    Right il tell ya what 2 do...! Start bleeding the back driver side caliper then move to the front passanger side and bleed it...! Then move back 2 the back passanger side and finish with the front drivers side....!
    And make sure your calipers are on the right way and theres no leaks in any of the lines.....!
    If you do all this and and it still don't work its your m/c because i hve seen them go when let run dry...!
    Good luck....
  10. #20
    Jesus just tought there lad the 2 lines going into the hydro might be the wrong way round.....! Check for that too...!
