Sig removed - See rules
That's part of the reason it over heated so fast in you.
Put the cap on + run for a few minutes until the coolant get to a little warm.
Then open that screw "the 1 with the sticker "dont open when hot" a bit ,until you see the bubbles coming out .
What's the rad cap rated to ?
rbs hate heat
ive never seen oiver 87 degrees on mine wit stantard fan and big radiator thermosate and everything is still in mine two usually sits about 82 or3 only seen 87 in tullow
dunno what the crack is with mine so
Murry Motorsport want €100 for a 11/12 inch compitition fan...![]()
