it depends if the car uses maf sensors or map sensors
i have a ps13 and the slightest boost leak causes the car to run like shit (maf sensor)
and i also have a 1jz supra which uses map sensors with this set up on a car you could remove every boost pipe and the car will still run fine (not miss fireing etc) just be down on power
so the characteristics of a boost leak are different depending on the car you have
so wot do you drive
