Results 1 to 10 of 14
    Senior Member joey's Avatar
    Default stainless steel roll cage
    one the boys is gettin a cage done this week,fella making it told him he making it with stainless steel.would this pass for prodrift?
    Cill Dara
    Best job would be to ring prodrift and say you have a question about the regs.. Just to be on the safe side
    Dont know what the regulations are but stainless is a stronger steel..
    drift Republican dR Dan's Avatar
    Cork.
    NO!!!!!!!!!
    Quote Originally Posted by joey View Post
    A stainless cage would only be good in a show car .
    Spec's for Prodrift cage:
    • All competing cars must be equipped with a 7 point or better roll cage. Bolt-in or fully welded Cages may be manufactured from seamless T45/T40 Chromoly, or mild steel tubing (Minimum wall thickness diameter of 2mil).
    Quote Originally Posted by Bobbys14 View Post
    No ,it's not.
    isnt satinless very awkward for welding
    Quote Originally Posted by Cooldrft View Post
    No ,it's not.
    Same size mild steel pipe and stainless pipe the stainless will be stronger.....
    di Member chris's Avatar
    it wouldnt be stronger on impact would be harder to drill through and cut thats about it.stainless cage would probably be worse than having no cage
    Quote Originally Posted by chris View Post
    There is a higher carbon count in stainless than mild steel increasing hardness and strength of the steel...
