i would go for the nistune option. It will cost you around €450 supplied, fitted and mapped by Stiv (over on sxoc). That way your ecu is tuned to suit your car and fueling.
I forgot to mention boost controller, actuator and walbro 255 pump.
first thing you need to do is get the idea of money outta your head and start buying parts bit by bit some stuff like exhaust/filter/front mount you can fit but until you get an ecu,injectors,bigger turbo etc wait and fit them all together then get it map'd jobs a goodun
First off, have a full check done on the car, compression/leakdown etc
Then get rid of any random ebay chip and the dumpvalve.
And finally, don't listen to any of the mcdonalds car park tuners!
Stage one consists of a complete exhaust system: downpipe, de-cat and cat back.(aftermarket elbo gives no advantage on the standard turbo), A front mounted intercooler, a walboro 255lph fuel pump, a decent boost controller and a set of 1 stage colder plugs.
This set up, with the boost at 0.85 bar will see 250 to 270hp on a healthy engine using the standard ecu.
The next step involves a new turbo(there are many options) a larger set of injectors and a mappable ecu.
A healthy RB20 can run up to and even a little above 400hp on standard internals.
If you want anything more then changing to an RB25 may be a better option as forged internals are not a easily found for an RB20.
www.inoc.ie
Irish Nissan Owners Club
Thanks everyone or the help and i'l get cracking on these as soon as possibable cheers![]()
[QUOTE=Wolftown;125960]This is good accurate advise, I am running 266bhp on my standard engine/turbo/ecu with a turbo back exhaust, walbro pump and boosting at 0.9. Not 100% what heat range my plugs are though, never changed them after putting those bits on the car[/QUOT
I definately need mine mapped am definately looking into gettin it mapped
www.inoc.ie
