na its simple enuf change dude ya do it in 15mins easy wit basic tools.
id try a pump you know is good anyway its prob jus gone weak the one thats in it.
if ya know anyone that has a 180 or s13 see can ya try theirs for few mins
My S14 Rollin shell For sale
I had the same problem with mine greg
wat i did was tried three 3 and it was only when i did all three it worked perfectly
- New battery
- New walbro 255 fuel pump
- starter motor refurbished
starts perfect every time since
And not to much expense in all that either
It started on the button this morning apparently. Good job Reuben.![]()
tanx, found a lot of 'loose ends' in d car dat are sorted now, but a full check over wud help.
but wit regards to starting, ecu was gettin crank signal etc.but dat FPR which was regulating fuel on the way back to the tank after it was already regulated wasnt helping.
also d vacuum lines to the nissan regulator wer more holy dan Tony Montana at d end of Scarface.![]()
Bump!!! It's not starting again.
