Results 1 to 5 of 5
Thread: front hubs?
    Default front hubs?
    im fitting front hubs from an s14 to my 180sx and i hear people talk about the holes in the hubs for the coilovers are bigger on the s14 hubs, wat will i hve 2 do to make them fit,?
    is it just get 14mm pipe on the outside and 12mm on the insde and press it in?
    Galway
    yup if you can find some pipe that will fit an the 12mm bolts fit into they'll do the job pefect
    finding it hard to get some pipe any other way of doing this?
    Galway
    i had the same prob...you can buy the inserts on frsport.com!!
    u can drill out the hole in the shock and use the s14 bolts or just bolt it up as is shouldnt move at all
