Results 1 to 10 of 11
Thread: bottom arms
    Default bottom arms
    what advantages would you get if you put s14 bottom front arms on a 180sx
    more camber. I stuck a pair on mine last week
    i like stuff
    does it effect the toe r the steering lock in any way then?
    as in would i get more lock out of it?
    knocks the toe out by a mile. Ive a pic of mine after i fitted them, il stick it up later if you want.
    I havent noticed any more lock, but im catching the bumpstops now and i wasnt before. The 14 bump stops are a different shape and size than the 180s though.
    i like stuff
    ya lad if u wudnt mind, is it the bump stop on the arm were the tie rod ends hits it on full lock???
    di Member Jay Rockett's Avatar
    Greystones, Wicklow
    It gives you more track-width, better handling and allows for more lock, once you fit them you need to adjust your toe as the arms are 10mm longer!
    to gain more lock id hve 2 mod the hub knuckles yes? as i already hve spacers betwen rack and tie rod.
    Greystones, Wicklow
    Yeah, if you've put washers in already then next thing really is a hub mod!
    You and cut and re-weld the position of your lock-stops too to get a bit more lock, or bash them back with a hammer!
    ya il say il get the hammer 2 it ha, hve 2 try find a set of modofied knuckles
    Quote Originally Posted by Jay View Post
    How do you adjust your toe? buy adjustable arms?
