any body got info on these turbo's have been told there good but want to find out more HELP please![]()
hard as fuck to get info on them man. Alot of people say there great but not many proving it. There seems to be a mountain of part numbers for near identical turbos too so hard to know exactly what your getting.
i like stuff
people on sxoc say there shit hot on a ca engine waiting on a reply about the sr
but be a small enough tubby if a ca is spooling them good.
Belive nothing without a dyno print out.
i like stuff
I don't know about therse turbos altough some belive there a great job....! At the end of the day there a lorry turbo and a lorry only revs to 3500rpm or so......! Don't know what they'd be like at 7-8.....! Also they just have an oil feed no water id be septacle bout that to.....! I know all thrust turbos are the same but there also based on a lorry turbo......!
Best thing you could probably do is find the basic size and model they are using and then look up the specs and compressor maps for the turbo. You should be able to match up the specific turbo you need looking at the different compressor maps for each spec
Greddy Turbos dont have water feed either, well the likes of the TDO6 and so on, doesn't make much difference when the turbo is designed that way. Also the revs the engine does won't make a difference, its the exhaust flow, like the blades in a turbo themselves run at 10,000s of rpm, like 100,000rpm.
