Results 1 to 10 of 24
    Cork, Ireland
    Default Single Pipe to Twin - Pro's & Con's?
    Hey All
    Just wondering is there any disadvantages to changing a single massive exhaust pipe to a twin set up?? If ya had a 4 inch pipe, what would be equal?? 2 2inch??
    Cheers
    TEAM MANFOOT
    Well half of 4 is 2 chuck so im sure 2 and 2 would be equal..... I also would like to know bout this....! Dan moorehead had a straight pipe back into twins and it sounded awsome.....!
    Go Drifting or Go To Hell Baz_180's Avatar
    Clare
    Well you would have more volume in the 4inch pipe
    A 24inch long 4inch pipe has twice the volume as 2 x 24inch 2inch pipes.
    Cross sectional area is all that matters
    pi r squared for the 4" gives you 12.56 square inches.
    So half that and it's 6.26" of area you need for each of the twin pipes.
    6.26/3.14 and square root of that and you get 1.41 for a radius which will mean you need two 2.8" dia pipes. So you'll either need 2" 1/2, 2" 3/4 or 3" pipe.
    Letterkenny , Co. Donegal
    Quote Originally Posted by DaveM-sport View Post
    Too many numbers there for me but does that answer the question
    Twin pipes are pimp! Mine sounds awesometastic. Theres all the answers you need
    Clare
    Oh right my bad! learn something new everyday
    Quote Originally Posted by Baz_180 View Post
    No, you were right. Two 2" pipes have alot less volume than one 4" pipe. I just used alittle bit of old basic maths to find out he needs two 2.8" pipes to have the same as what he has now.
    It's just that maths is pretty had to write and explain on a forum
    Therea more too it than just volume like friction losses, turbulence and all that shit in the different sizes of pipe but fook going that far
    Pros would be, the twin pipes sound better.
    Cons would be the system would be heavier than a single pipe and it's twice the piping you need to make again if you break it or it falls off
    Yowdy has twin pipes on his so try asking him ??
