Results 11 to 20 of 21
  1. #11
    di Member Dozzler's Avatar
    Mitchelstown, where men are men and sheep are nervous!
    Anybody got an afm for sale with the connection attatched? maybe cut the wires about 5" back?
    Jeasus you have a big knob!!! Poke an eye out with that thing!!
  2. #12
    bbuummpp it up now
  3. #13
    right got the afm sorted n she's driving grand again but cuts out on idle, turbo timer says the battery level is not goin above 11.6 most of the time? Do these symptoms indicate fooked alternator? If so will it be ok if i get it rewound?
  4. #14
    May 2010
    glad me old afm did the job for you, generally i woulnt trust the voltmeter on a turbo timer/ boost controller but YES. . . ur alternator seems fooked,probly the brushes, get it overhauled , she will be mint
  5. #15
    May 2010
    also, check all ur connecions on the alternator and ur earths, before u take it offf, could be that simple
  6. #16
    Thanks very much lad. Yr a gent. Keep me posted on the gtr indicators.
    A1.
  7. #17
    Default Help
    Ok i never did anything about this cos it fixed itself after that but now it's gone all fucky on me again. Smoke and splutters on cold idle. . But when warm it's boosting and driving way better than ever but wont tick over itself, i.e it cuts out once revs go below 1100rpm.
    Electrics or what lads??
  8. #18
    You could try cleaning the idle control valve "it's at the end of the inlet manifold".
  9. #19
    Quote Originally Posted by Cooldrft View Post
    Will do, thanks cooldrft.
    Note: The two times this occurred was when I jump started the car after having left the lights on, also the battery didn't hold charge after jumping and driving for ten mins, parked it up again and had to jump it again after a half hour of being parked, drove 20 miles over the road and now it's holding charge but still have running problem???
  10. #20
    I Rustle Jimmies twin-cam85's Avatar
    Quote Originally Posted by Dozzler View Post
    scrap it
    If It Aint Rubin, It Aint Low Enough
