Results 1 to 10 of 13
Thread: cage problem
    it should be tight to roof an A and B pillars even if its bolt in!!...it needs boxes welded into the floor to bolt the cage onto!!
    no the cage wouldn have to be welded to the boxes you could jus bolt it to them!
    but the boxes would have to be welded in.
    rite no bother ill have get box for them, iam only down the road from a steel fabucator, drop into them see what they have
    jus make sure on the boxes for the cage they weld nuts on the inside of the box where the bolt holes for the cage are goin on them so you've somethin decent to bolt into
