Results 1 to 8 of 8
Thread: fitting a cage
    Default fitting a cage
    hey all
    iam getn a half cage for the silvia and woundering can you fit it you self or
    worth getting someone to fit it for ya...............
    like have ya got to reinforce where you bolt the cage on to the car to spread the weight if you ever give the car a smack?
    also what involed in fitting it
    it a bolt on cage as well
    john
    Dec 2009
    Theres nothing to it lad.....! Just fit it in and drill and bolt the plates in top and bottom....! Pretty simple......!
    ahhhh ok, just talking to me da, he a x rally driver, said they use todo put plateing behind where you where gona bolt on to the body to spread the weight, rather then putting all the stress on one spotit will spread it out...........
    that sound then ill get working at it next weekend
    ill give ya a hand to fit it john if ya want have fitted loads a them
    Quote Originally Posted by podge View Post
    ill be in touch, have get few bits weld, from the feed back iam geting.........
    a dogy fitting cage is a death trap
    you have one in the silva and the linner, yours weld or bolt on
    bolt in in the silvia and weld in in the skyline
    once u plate both sides of the chassis and use heavy bolts 8.8 i think i used cage will be fine in car make sure and get padding for the main hoop as its a road car
    sound, oo defo going orange and black, but hope half it next weekend
    where do i get the paddin for the cage????
