Results 1 to 8 of 8
    Default FPR adjustment??
    Just fitted a nismo FPR and gauge to my sr20.
    What Pressure would be best to set it at?
    its running Standard injectors with a walboro 255 lph fuel pump
    Also i was just adjusting it earlier when i put it above 50 psi the gauge starts to fluctuate up and down.
    Why would this happen??
    Thanks in advance
    there usually set at 3 bar or 3.5 and as the revs increase the fuel pressure increases
    Should be 3.5 bar approx, 3.5 with the vac off if i remember right.Then should sit at 2.5 bar with vac and go up to 3.5 under load.
    Cheers lads
    Site Trader: TDP - Trackday Performance
    3 bar with the vacuum off. You should have the car checked on the dyne to be sure the far is safe.
    Robbie
    Cheers Robbie any price on a dyno run??
    A 2 wd dyne session with full AFR graphing is 110 inc vat.
    Robbie
    Dont alter fuel pressure on a car unless your mapping it..... 2.8bar @ idle
