Results 1 to 10 of 11
    Default offset question..??.
    mite be gettin set wheels today and offsets are et40?
    good or bad?
    bad
    does that mean they'd be dead straight?
    Oct 2009
    They'd more than likely sit a bit inside you arch depending on width, The lower the better, - offset is better.
    widths are 9.5 rota gtrs?
    goin on front of silvia..
    Administrator
    they are weak. I wouldnt bother. there the flat rotas!
    i taut the 9.5's are good dish?
    whats the offset so?
    Administrator
    you can have lots of width, but without offset there still going to sit inside the arches, just means theyl rub off suspension
    theres 30mm spacers on front, has 30mm origin front wings! that make a difference?
    Administrator
    Ah, ya might get away with it then alrite!
