Results 1 to 9 of 9
    you can take the full rear setup but not the front get the front discs, calipers and get a set of s14 5 stud hubs and it will all bolt on you will need to drill out ur 2 bottom strut bolts thats all
    May 2010
    Why won't the fronts fit??
    because the arms are in different places
    just go with 14 hubs all round then use ur r33 discs and calipers.its all bolt on that way
    Use the s14 hubs all around but use the r33 brakes all around.
    May 2010
    @Muttly-can i use the R33 shoe handbrake setup on the 14 hubs aswell??
    Ya you can. You need the back plates from the r33 hubs though along with all the gubbins of the brakes.
    I've r32 parts on my s14 hubs.
