Results 1 to 10 of 13
    Default rb26 conversion???
    hi i have a gtst r32 rb20det just wondering is it much work to convert to rb26dett , it will prob cost a bit but if anyone has a few hints or tips it would be great.thanks
    Quote Originally Posted by stevokr32 View Post
    Buy a gtr
    haha i mite buy full will see how money goes.
    Pro Driver
    i have a complete rb26 engine + box due in a few weeks if interested
    im doing the same in my 32 gtst .u will need.engine box loom turbos afms fuel pump and alot of other small bits rad etc.i have a number here for a lad that has complete convesions if you want
    that great lads pm me details please if you can.
    should have a full gtr for breaking in the next week or so
    SR20 it,Only way!
    di Member mick-skyline's Avatar
    Quote Originally Posted by Mick K View Post
    SR20 it,Only way!
    lol
    not much work really if you call taking an engine out and putting an engine in not alot of work, only thing you need to modify for it to sit right is the sump you need to cut the diff housing out of it, and weld it up, but also making sure it doesnt hit the ARB/front subframe but also leaving enough of a size for the extra oil the 26 uses due to the twin turbo set up, so ya cant take too much out of the sump either, little bits at a time,
    then you need to wire the engine loom onto your existing loom and also fit a gtr ecu, you'll need an rb25 gearbox too to keep it rwd which im sure you want, as the rb20 one wont last too long with the rb26. and with the 25 box you then need to work out a way of converting your speedo to read from the sensor as its a cable on the rb20.....
    thats about it really, well what i can think of at this time of the morning after a night of work...
    thanks for the info guys hope to get started ina few weeks cheers.
