Results 1 to 4 of 4
    Default reversing sensor
    i got a sensor yesterday for da 180sx. the one that screws into the box but its all arse ways now when i turn the car on the lights are on and when i select reverse they go out! the sensor is out of a cafiro are they different?? he says the problem is before the switch? anybody know wats up?? thanks in advance.
    switch the wires around
    di Member okachan's Avatar
    Default reverse light switch
    hows it goin lad ,
    sound like a bad earth,
    there only a two pin connector, check for a chaffed wire running alond the box loom , and make sure the right type bulb is in the holder,and no corrosion on the parts involved.
    also bridge the connector block with a piece of wire select reverse and switch on your lights,
    [IMG][/IMG]RUNNING_LIFE
    Quote Originally Posted by okachan View Post
    hows it goin lad ,
    hey man
    ye i already bridged it with a wire but i didnt need to select reverse they just came on. the bulbs are the right ones. do you think maybe its a different switch?? or are they all the same?
