Results 1 to 10 of 16
Thread: knock from diff
    na sounds fine all 2ways are bit knocky wen turnin slow an reversin an stuff...depend how rough the surface your drivin on too the rougher it is the more it'll knock
    di Member Romo's Avatar
    Wicklow
    does it knock at all goin straight? if not then its graaaaand
    di Member m-sykes's Avatar
    same thing happened mine lad, fukin gigglin pin went. just put in a new one and she'l be sound
    Sig removed - See rules
    JZ For Life! Greg's Avatar
    The gigglin pin on the laughing shaft?
    The two way in my car doesn't knock and bang at all. Skip the inside wheel alright but never knocks and bangs.
    yea exactly its a cunt of a job lad some are just different
    di Member KVZ's Avatar
    May 2010
    Mullingar/Athlone
    as above - all 2way diffs make noise when turning.You can reduce noise by using different oil (I have 2way kaaz diff , I`m using motul 90PA oil and ist a lot better then kaaz oil)
