Love that car
lovely looking car
leathel love s15's an that is tidyyyyyy fair play til ya lad
really liking this car
well with exams over and abit of TLC need be done to the car, i had her up on some axle stands.
I was getting abit of play on the rear driver side wheel, found it to be the wheel bearings on the way out so decided to change them out with a spare set i had laying around.
while i was at it started to fit my Z32 alunium upright/knuckle mode i had been planning for a while now.
only managed to get one side done..
dame weather!
refurbed lower arm powder coated polybushed and adjustable roll centre
Conical spacer required for fitting ball joint to alumiunm knuckle.
knuckle was fitted with a rose joint to allow maximum movement of the suspension mount as the z32 suspension is actually at a slightly different angle.
test fitted the knuckle inplace
cut and welded an old suspension bottom mount to take the Z32 fitting.
a few problems in countered while doing the mod.
dust cover on axle needs to be removed as it rub on the rear of the knuckle when bolted on fully.
and some grinding need on the z32 knuckle/upright where the suspension bottom mount bolts on, cause of full supension travel the knuckle hits the bottom mount.
*** Update car is Sold... gone out of ireland !!!
pics deleted cause it makes me sad to see it..
