Results 1 to 10 of 21
Thread: sr20 rough idle
    di Member chris's Avatar
    anyone any other suggestions or any more on what niall said.
    was driving today and it cuts out when the revs drop say commig into a roundabout or traffic lights etc.its wrecking my head has to be something small cause was running perfect before i parked it up
    di Member m-sykes's Avatar
    Quote Originally Posted by chris View Post
    id say either your afm or lamba sensor, id get different ones and try them out
    Sig removed - See rules
    Quote Originally Posted by m-sykes View Post
    its a brand new lamba sensor so shouldnt be that will see if anyone around has a z32 to try it in mine
    when you rev it to the floor how far does it go up on the rev counter?
    i havnt rev'ed it that much really.didnt take any notice
    besides that the car is driving fine not down in power or anything
    rocker cover gasket was leaking so changed that today changed the manifold to block,manifold to turbo,turbo to outlet and outlet the turbo gaskets too.changed the oil and filter again threw in one of them engine flush things.new spark plugs and painted the rocker cover.its running perfect now thank god
    Feb 2011
    cork
    i have this problem too when driving the car and when you stop it almost cuts out, i have cleaned the the iacv and it still does it, when it warmed up it fluctuates up and down a bit in the revs.
    is it the plugs,
    afm
    02 sensor
    fuel pump? as of latley a bit of a whinning when pressing the accellerator.
    also i only flushed the iacv with carb cleaner when i took it off i didnt take it apart or anything.
    HELP PLEASE
