Results 1 to 10 of 19
Thread: steering??
    Greystones, Wicklow
    Check your powersteering fluid level or check it for leaks! if you have much negative camber that'll also make the steering heavier!
    But lowering the front will add more weight to the front wheels so steering will be heavier..
    mines pretty damn heavy too, its heavier than my manual rack ae86! must top up the fluid when i get a chance/remember
    Senior Member ste's Avatar
    north dublin
    fluid is ok jay and there is neg camber on front not sure how much though it cant be too much as tires still lookin ok 6months on so just find it quite heavy for normal drivin
    i think skylines are heavy as stantard i know mine is anyways
    di Member Jimmy's Avatar
    Ye man my 32s heavy enough compared to me mates cars i dunno, i know i need new track rods tho just keep forgetting to sort it.
    di Member mick-skyline's Avatar
    the size of your wheels added to the neg camber along with the lowering of your car all make it that bit heavier ste. plus you need a track rod end too dont ya....
    north dublin
    booked in with the legend that is NISSAN DOCTOR tomorrow for few bits to be adjusted so will have a look then
    Greystones, Wicklow
    Quote Originally Posted by ste View Post
    Yeah it could be the fact that its a big 4dr with a 6cylinder lump up front, did ya
    try putting your engine in the back??
    Ah no, maybe try a little less negative camber and if its not making much of an
    improvement then you'll avta put up with it, ha! I find my steerings heaving in the
    silvia too but thats cause iv a slight leak and 18x9.5's with alot of spacers and a bit of negative camber!
    north dublin
    Quote Originally Posted by Jay View Post
    ill get it checked further as i gettin new track rod ends fitted over next few days
    Stop being a girl
