Results 1 to 6 of 6
    Default DD 510 sub + box
    DD subs doesnt need any introduction for these who know something about caraudio.
    Here i have the smallest sub from this brand. Its a 10" DD 510
    Details:
    DD500a
    The newly upgraded 510a and 512a subwoofers bring DD impact and durability to the most affordable price ranges we've ever offered. You still get the hand built, high performance quality at a price within every budget. The 500a Series was designed to optimize performance from amplifiers in the 100-400 watt RMS range. Not everyone is going to try to crush their tonsils with the latest bass-jacked MP3, but that doesn't mean one should have to settle for lower quality parts or design.
    The 500a series woofers benefit from the highest quality parts available, close production tolerances, and hand built quality as do all DD woofers. The motor and moving systems have been designed to get higher efficiency from lower powered systems. We found ways to reduce mass from the cone, surround, spiders and voice coil which raises the efficiency on a given level of power. The suspension stiffness and excursion capability were carefully dialed in through many real world test samples. The result is a very fast woofer capable of delivering surprising output from modest power sources.
    The 500a Series feature multiple layers of durable cloth in the spider system, our exclusive laminated lead wires into the spider layers, double laminated half-roll surround, non-pressed cone and a motor system modeled after the 3500e Series woofers. The 510a and 512a are very easy to use in vented, TLs, and specialized band-pass boxes and are the perfect presents in gift boxes. Now there aren't any excuses to get anything less than a DD system in every car.
    We recommend to allow at least several weeks of playing time to break in DD Woofers, full break in may take many months. DO NOT play subwoofers at max amplifier power in the first couple of days, give the suspensions a chance to loosen up. As the suspension breaks in, the subs will play lower and louder.
    After you give the woofers a chance to break in (you'll know when this happens because the woofers will be playing lower and louder) you can start to look at port changes to alter the sound to your personal taste and your vehicles acoustic loading conditions.
    Optimized for 100-300 watt systems
    Multi-layer spiders
    Laminated surround
    Double stack magnets
    High-temp voice coil
    Laminated tinsel leads
    Hand-built quality
    Rubber Magnet Boot
    | Mounting Info | Enclosure Info | DD Design Philosophy |
    Printer Friendly Version
    SPECIFICATIONS
    Series 500a
    Voice Coil Diameter 2.0"
    Magnet Weight 90 oz
    Power Handling RMS/Peak 300/1200
    Suspension 50 mm
    Nominal Impedance 4.0 Ohm
    DC Resistance 3.4 Ohm
    Model 510a 512a
    Rec Box (cubic ft) 1.5 2.5
    Port Area (sq in) 22 36
    Port Length (inches) 16 16
    Woofer Diameter 10" 12"
    Free Air Resonance
    38 Hz 36 Hz
    Qts 0.405 0.433
    Qes 0.461 0.499
    Qms 3.29 3.29
    Vas 23L 60L
    Sensitivity 86.5 dB 89dB
    Shipping Weight 13 lbs 14 lbs
    Box is made by myself and is tuned onto 33hz and 1.5 cuft + port
    SIze:
    Height - 32cm
    Width - 50cm
    Depth - 40 cm
    Sub have seen around 30 min of playing, have a transport box here and receipt for 147 eur here.
    Got it last year from DD dealer from Belgium as you cant find this brand in Ireland.
    So the sub needs to "break in" around 20h at least when the better sounds starts to come out of it, like the same with all the subs.
    My selling price is 130€
    Which means you get the box for free
    Same sub (just newer version) for sale in Germany, where everything is cheaper than here: http://www.hifi-music.de/shop/Digital-Designs-DD-510-b
    Still for sale
    130€ offered, anyone closer ?
    I can see theres no interest for quality for a GOOD price
    Way to go Fusion crap
    Price drop:
    130€
    Can split it, so sub itself will be 80€ so ...
