Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Default Clutch Bleeding.....!
    Lads my clutch won't bleed.......! No pressure in the peddle until 3/4 way down......! I think the slave or master cylinder could be fucked but any other ideas lads........!
    How are ye doing it?
    Mine bled grand not so long ago
    Didnt Meego have a problem bleeding his aswell recently
    400 horses............. 1 jockey
    Quote Originally Posted by Frankae86 View Post
    Yea it took us ages to bleed mickos but mine is taking the piss......! I don't think theres any air left in it and its not pushing the pin in the slave cylinder far enough.......!
    {Didnt Meego have a problem bleeding his aswell recently }
    ye i had a problem wid brake master cyclender frank, robbie has clutch trouble:
    Ya sounds like you down on pressure
    I never had a cylinder go so cant say but it would be hard luck to be gone when you had the box down
    Quote Originally Posted by meego1 View Post
    Oh thats what i was thinking of
    Il try the slave first tommorrow evening.....! You all set frank did ya get your box sorted....!
    rite lad iv had to do this heaps of times to get a pedal on nissans it will take 3 people to do it safely, one in the car on the pedal and 2 under, get a vise grips put it on the clutch fork beside the slave cylinder pin, one person pull out the vice grips untill the pressure plate is relesed(do the job that slave cylinder normallly does) other peron will have to hold the pin of the slave cylinder while the person inside pumps the pedal when the slave pin comes out enough to meet the clutch fork get the person inside to hold down the pedal and relese the fork slowly with the vice grips at this stage the person holding the forks arms will have fell off!!
    good luck
    ^^^I lol'd at the last line
    Gem your a fucking star........! If this works your an even bigger legend than you already are.........!
