Results 1 to 4 of 4
    Go Drifting or Go To Hell Baz_180's Avatar
    Clare
    Default Remove AirCon???
    I was thinking of removing the aircon system from my car in a bid the tidy up the engine bay. Has anyone else done this? is there much work involved or any tricks I should know about?
    Meath
    Done it to the silvia pretty simple when removing the first pipe (which ever one) mind your eyes i opened the first pipe and got sprayed with green sh*t, then simply remove the pump and housing on the engine, radiator and all pipe to the bulk head, i covered the pipe's then that stick out of the bulk head incase it was ever to go back in!!
    Clare
    Thanks for the info! sounds easy enough I'll defo give a go so
    u can take the pressure off the system by letting the air out of the top up valve
