Results 1 to 10 of 21
    Keep tension on the chain and dont let it slip on the crank sproket other than that its straight forward
    400 horses............. 1 jockey
    Croom/Adare Co Limerick
    Default sr engine
    thanks for reply lads and with reference to my timing marks my inlet cam is pointing to ten o clock and my exhaust cam is pointing to 1 o clock and piston number one is at TDC..........where should my bottom pully wheel be at i think it second notch from left..... is the above right??
    the crank should link should be at 5 o clock
    Default sr engine
    ya it is pointing to 5.......do i have to line up 1 of them little cuts wit that pin that stickin out..... i think it second from left?
    the pin on timin chain cover wit the 2nd marks from the left on crank pulley??ya that'll line up like that if its rite.
    Default sr engine
    sounds good to me i think it is right just wanted to double check
    thanks a million for the info
    ah if the cams an crank are lined up your sorted dude jus lump the cas back in rite an double check the timin
    Quote Originally Posted by 180sxbreaker View Post
    It should be exactly as above. Have you removed the oil pump collar from in front of the bottom pulley?
    www.inoc.ie
    Irish Nissan Owners Club
