get a boost controller an knock it up a bit man it'll help wit the lower comp...as long as you've an upgraded fuel pump you should be able to run .9 bar safe enuf befor mappin...you can wit the sr's anyway...350 wasnt bad wit wiesco's an a cometic mhg an a mint head an clean block...is it runnin standard bearins??
