you get a fmic for handy enuf moneys specially if ya buy 2nd....much the new engine set ya back??
My S14 Rollin shell For sale
http://www.driftireland.com/forum/sh...ad.php?t=31509
350... im happy with that tho, got a decent amount of stuff, wiesco's are huge money for them, cometic gasket, reground crank and all the bearings, block is mint, no corrosion, head is a recon or exchange job it brand new!hopefully now itll go abit better! itll prob b slower now as its low comp an ill b running the same boost! not for long tho
would you not use that Volvo intercooler you have??? That thing is pretty damn big like....Cool beans otherwise
get a boost controller an knock it up a bit man it'll help wit the lower comp...as long as you've an upgraded fuel pump you should be able to run .9 bar safe enuf befor mappin...you can wit the sr's anyway...350 wasnt bad wit wiesco's an a cometic mhg an a mint head an clean block...is it runnin standard bearins??
its alive! was abit worried when i started it as its missfiring, but i think i have that figured out now, think its an injector, have done a comp test an it fine, took out plugs and cleaned them, put them back in and ran perfect for about 4 seconds, then started missing again, pulled out plug no.4 and it was soaked and smoke comin outa cylinder awfull smell a petrol off it, so im gona change them out tomoro an hopefully itll b all gud!![]()
woohoo vid and pics or it never happened!!!![]()
