Results 1 to 10 of 11
    Default sr20de to sr20det??
    looking to do a conversion will i nead a sr20det gear box and diff or are they the same ratio box and diff??
    wat ezacualy will i nead to du it??
    wud i b better off to buy a crashed nissan and take parts from it r buy them seperatley
    only need to change a few plugs on your loom lad nothing els
    wat bout the internals? are they the same as a turbo 2 a non turbo i dnt thnk they are i cud b wrong
    Sr, Lad!
    No not the same internals, pistons, oil pump and jets and more iirc
    with the price of cars at the mo i reckon it'd be worth buying something crashed.
    ur n/a box will be made of even softer chocolate than a turbo sr20 box, gem has a 180 for breaking!! engine and box there and its 110% as i owned it the car for a short time...
    engine box (ecu/loom if urs cant be spliced) if ur going turbo
    clarkey ran a non turbo box in the bdc last year and he was pushing 400bhp so go for it
    di Member Deco84's Avatar
    Oct 2009
    Dublin North/West
    im doin a conversion at the mo opted for gettin a crashed yoke works out cheaper ,
    as far as i know the na box is the same as the turbo
    Quote Originally Posted by ian g sr20 View Post
    are you converting your de to run a turbo or swapping engines for a det?
    i like stuff
    i will b changing the engine to an sr20det, just looking 2 find out are the box,s and diffs the same
    Sr, Lad!
    what car is it 13/14/15?
