Results 1 to 3 of 3
    Default Maxxis BDC Semi-Pro round 2
    God bless BDC and there FB updates
    The top 8 qualifiers
    8th Marcin Klawikowski
    7th Martin Griffiths
    6th Matt House
    5th Phil Maclachlan
    4th Mike Cooper
    3rd Adam Brackwell
    2nd Ian Phillips
    1st John Glaister.
    Head to Head
    Team mates Phil and Mike will meet in the twin battles with the other battles comprising Martin v Ian, Matt v Adam and Marcin v John.
    Phil loses his front and back bumper in the practice run with Mike Cooper. Mike spins and Phil continues his run. 10-0 to Phil first run.
    10-0 to Phil second run as Mike spins near the finish. Phil goes through to the Semi-Final.
    Martin Griffiths v Ian Phillips - 8-2 to Ian Phillips as his run matches his qualifying run (which was in the dry) - the wet track didn't affect his commitment or entry.
    Second run 7-3 to Martin Griffiths as Ian Phillips straightens after the first and final corners. Ian goes through to the semi-finals on the strength of his first run.
    Adam Brackwell ends the first judged run wedged against the armco barrier as he spins near the finish line. 10-0 to Matt House. Recovery truck is out!!
    Adam's car is recovered and in the second run Matt House spinsafter the final corner giving a 10-0 result the other way! They'll have to run ONE MORE TIME!
    7-3 to Adam on the first run and 6-4 to Matt on the second - Adam goes through to the semi-finals. Matt straightened twice on the first run and Adam straightened once on the second.
    Marcin v John Glaister - 7-3 to John showing some awesome driving today!
    Second run 7-3 to Marcin as John makes a mistake on the first corner. They'll have to run one more time....
    John makes a mistake on the first corner causing him to straighten. 6-4 to Marcin.
    7-3 to Marcin on the second run as he has a clean run and John makes a couple of mistakes.
    Final 4
    Phil v Ian first judged run - 7-3 to Ian as Phil straightens during the run.
    Second run 7-3 to Ian as Phil straightens during the first corner. Ian carried the angle and speed throughout his run.
    Marcin initiates late and straightens giving Adam a 6-4 advantage in their first run.
    6-4 to Adam on the second run so Adam is through to the final against Ian Phillips.
    3rd & 4th place run off.
    Phil does his best entry of the day! He straightens slightly later in the run but Marcin straightens for longer giving Phil a 6-4 advantage.
    Marcin spins in the second run! Marcin is 4th and Phil gains 3rd place.
    Final
    First run of the final sees Ian gaining an 8-2 advantage over Adam as Adam straightens at various points throughout.
    In the second run both drivers put in a safe performance resulting in a 5-5 score. Ian Phillips wins on the basis of his first run!
    Pics
    http://doristars.com/v-web/gallery/rdcspr2
    Also see www.drifted.com for full report
    di Member jap scrap's Avatar
    them 2 blondes are savage
