Results 1 to 10 of 17
    Default what model turbo is this?
    lads this turbo came in on my ps13 from japan over a year ago it said on the auction sheet that its an uprated turbo and now that ive the engine out getting the big ends done i said id fiond out what turbo it was does anyone know what model it is?Attachment 1956
    Attachment 1957
    any code on it?check the plate.turbo could be damaged if your bearings went.The oil in the engine goes through the turbo you know
    Sr, Lad!
    fairly sure its s14 t28.
    ye check the i.d tag on the core it should have some part numbers it could be gt-ss either
    i googled the numbers on the turbo and now im fairly sure its a garrett t3/t04e 60 trim
    has anyone ever used one of these ort have any info on them there supposed to be good up to 490 whp
    Quote Originally Posted by johns13silvia View Post
    im going to say im sure its not! as t3 have a bigger flange on the mani sind and dont have a bolt on intake flange or output id say its just a t28 off a 14 put up the numbers??
    i havent looked at the core yet as its still attached to the engine its the numbers on the core ya need is it?
    ye on the lil alloy plate
    sound ill have a look at it when i take it off
    dont mind wats written on the housing its the core is were the info is and who ever gave ya dat figgure is talkin shit common sence should tell ya such a small turbo wont produce that power
