Results 1 to 6 of 6
Thread: N/A to Turbo
    di Member Daraghs14a's Avatar
    Ennis
    Default N/A to Turbo
    Question:
    Is it a big job to go from 180sx na sr20de to a sr20det?
    Whats needed to be convert over to turbo?
    Any one done this?
    I know of a couple of people talking about doing this, its worth a shot id say.
    exhaust manifold, ecu, injectors, tubby, fmic, downpipe, necessarly vacuum oil and coolant lines
    since its na its already running higher compression so running low boost should give nice power. get it properly mapped too.
    it would be interesting to see what way it would work out..
    Ennis
    Ya you could try make the sr20de a sr20det but probally easier put in a det engine i would think,
    Youd more than likely melt the pistons in a de engine with a turbo on it.
    cheapest option is to just drop a new engine in.
    Quote Originally Posted by 200sx View Post
    This site is made up off a majority off absolute wank bags,and im sure im one off them from some peoples point off views,all nice fellas in person,but just a bit off a keyboard braveheart.....Thats the way this site is plain and simple,either like it,or sling your hook!!!
    Cheaper to simply put an sr20det engine into it.
    The expensive of making an sr20de function as a det would be more then a conversion.
    Its low compression pistons which are needed for turbo'd engines so even if you did turbo it it couldn't(safely) be as powerfull as a det
    www.inoc.ie
    Irish Nissan Owners Club
