Results 1 to 10 of 12
Thread: help
    kerry
    Default help
    anyone know where a crack shaft sensor is in a sr20det??
    the story is my 180 started running lean all of a sudden then i thought it was just went and bought a apexi pfc and put in the 550cc injectors high pressure pump adjustable fuel pressure reg and z32 afm so brought it to get mapped but no joy couldnt be mapped or fault couldnt be found so i brought it home again and put all standard bits back in (injectors afm etc...) but it was still the same. could a idea about and hour ago to plug in our diagnostics and the fault came up as a ''crank shaft sensor or wiring'' so does anyone know whats up with it??
    and also forgot to say its only running on one cylinder at the moment
    help needed asap please????
    only running on 1 cylinder who was doing the map/fitting pfc??
    kerry
    john allen at west coast performance
    Its the CAS. The SR20 doesn't have a sensor that reads the crank directly, The cam angle sensor as its normally known is actually the crank angle sensor.
    Have you removed it at all? It has to be fitted a certain way to work properly.
    www.inoc.ie
    Irish Nissan Owners Club
    kerry
    no didnt touch it until i thought of changing it so i changed it and the same thing but i think the one i got is fucked aswel. i put it in the right way i think
    i typed it in on google and it showed me some ting about marks on the timing chain is that the right way??
    no u need to line up two dots on the cas iirc(its last yr since i was at mine)an put it into the head an then make sure there still lined up wen its in places...engine has to be a top dead center too
