with that size wheel, the centre line of the wheel will be pushed out away from the hub with the negative offset.
you'll need 12cm's of clearence on the back of the wheel between the hub face and anything likely to be hit by the wheel (shock body),
and 17cm's of clearence on the arch side to have them fit.
and almost definitely need a bit of arch work?
cut away the arch lip and fit a set of textured black jun arches?
