Results 1 to 10 of 11
    fuel pump!?
    ^^ beat me too it.
    Its gonna be costly unless he gets it sorted quick. Does he know what pump it has or how old it might be? or what size injectors and fuel pressure hes running?
    Shouldnt be a need for a swirl pot unless your sucking major petrol. Its not cheap either, im going down that road at the min
    ill find out asap and get back to ya's
    ok lads,
    atm he has,
    555 walbro's - not sure of pressure,
    his turno is rated at 470 bhp on HIGH boost,
    so he ir running LOW boost atm,
    trip to get 740's in order??
    Try start with a visual check of the pump and housing make sure it hasnt come off its slide in the tank etc
    Greystones, Wicklow
    Uprated pumps arnt the most reliable compared to standard ones so it could be just nakerd!
    I dont think nissans generally suffer from fuel pump starvation and need swirl pots..
    Try get a lend of a working uprated fuel pump and stick it in, it has to be an issue with the tank/pump if its ONLY effected by cornering etc..
    Quote Originally Posted by Jay View Post
    x2 jays on the ball here
    Quote Originally Posted by serious love View Post
    ok lads,
    atm he has,
    my bet is that if you upgrade to 740s you will only sreatch the demand for fuel more also cause over fueling,
    ok lads thanks ,
    he has been told
    ill keep everone updated
    thanks
