Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
  1. #11
    di Member m-sykes's Avatar
    Quote Originally Posted by PeterT View Post
    turbo timers are a waste of time, take it out if its the problem!
    ya think man? i never really use it unless im after after bombing it down the road, do ya need tham if your driving easy before ya turn the car off?
    Sig removed - See rules
  2. #12
    Administrator
    No. Even if youve been driving the hoop out of it, cruising back to your house for a few mins will have the turbo back to its normal heat, and then when you stop, leave it idle for like 10 seconds then knock it off, be grand like that!
  3. #13
    arite cool, never knew that man, thanks bud
  4. #14
    JZ For Life! Greg's Avatar
    What he said. I only use mine for warming the car up for five minutes before I leave the house.
    My JZX100 from grandad mobile to drift toy thread.
    --->>>>http://www.driftireland.com/forum/showthread.php?t=121
  5. #15
    Quote Originally Posted by Greg View Post
    like letting it tick over without the keys in it?
    or is it a remote starter you have
  6. #16
    Quote Originally Posted by m-sykes View Post
    Ya. Just start it up, set the timer for 5 minutes, take the keys out, lock the car, and go back into the house and finish off the girlfriend.
  7. #17
    hahaha good lad
  8. #18
    di Member 1jsoarer's Avatar
    i dont think its the altenator when the battery is full of charge after every drive at night, its only if i leave it over night
    it is man, the altenator has things like contact points in it, that when your battery is fully charged they either open or close to complete or disengage the elec circuit!! i forget which way!...but anyway they wear out and stick. it'l still charge the battery but it'l also drain it
    Turn off every thing in the car, and see if there is a spark when your connect the battery lead back on.....usually a sign
    Fuck me that was sum speal....
  9. #19
    laddddddd
    its your battery is fecked. ever listen to how your car turns over when you try to start it. getting crank tomorrow
  10. #20
    The Monstar!!
    Quote Originally Posted by 1jsoarer View Post
    mate it could be anything drainin the batt it might not be the alternator... could be 1 of 100 things!!!
    likely problems your batt could be foooked or as ur man said check the drain on the batt with a multimetre with everything turned off.. if its a larger drain is more likely a solenoid smaller could be a sensor.. then start disconnecting things and keep checking the multimetre until it drops...
