Page 5 of 5 FirstFirst ... 345
Results 41 to 50 of 50
Thread: new daily!!
  1. #41
    also! nice air filter and afm! haha
  2. #42
    yessss i need to get that other one back off you cos ill havr to change the power steering feed and dont wanna mod it till i have the filter that will be staying for good
  3. #43
    Cork, Ireland
    Impressive, very impressive..............always wanted to bolt a Turbo onto something!! Or put like a Gt35R on my Audi Ha! Keep the pics coming mad man.......
    TEAM MANFOOT
  4. #44
    Quote Originally Posted by Chuck_g View Post
    haha do it!!!!!!
    not many pics today as i forgot my cam this morn
    did very little anyway! front mount on and pipe work finished, front bumper cut to shite looks cool!, det injectors are in, det ecu is in, auto box, ring gear and torque converter are in the scrap heap where they belong!!! light weigt fly wheel and exedy clutch are bolted up, clutch pedal- master and slave cylinders are in
    left to do:
    bolt rb bell houseing on to sr box, and put that in
    fidle around with some shafts to get the right lenth prop u sickos
    put in a diff undecided atm prob just put in a viscus insted of welder
    put in walbro fuel pump ick
    bleed valve and boost gauge
    lower the shite out of it
    most important drive the crap outa it!!!!
    clutch and fly
    in!!
    rb bell houseing
  5. #45
    wicklow
    ah the clutch out of me owl laurel
    shes comin on well gem,i shud be out there to ya later on
  6. #46
    JZ For Life! Greg's Avatar
    You're flyong alog with it Gem, fair play. I bet you can't wait to get it out and to start the weckage.
  7. #47
    bit done today not a hole pile put box together them put it in then back out now in again!!! cunt of a yoke! prop is all done front section of a 180sx rear of a type m r32 gtst gear selector hole is all done and finished
    sr20 box
    rb20 bellhouseing
    rb left sr right
    remove 5 12mm bolts here
    pull plate off
    looks like this
    remove clip around the outside of the bearing(not the circlip on the spigot shaft)
    then remove all the 12mm bolts around the middle of box
    few gental belts of a sledge hammer!! lol looks like this
    sr left rb right see the same exact patern
    sr speedo drive electric
    rb speedo drive cable
    just pull out the 10mm bolt then they just pull out
    bumper cutage!!!
  8. #48
    comin along now gem
  9. #49
    its alive!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!! drove it tonite all went very well exept i never bothered to change the fuel pump as i just wanted to drive it the stock na pump is not able for it!! and haveing a small prob keeping the boost down it will be grand thow
    first start up
  10. #50
    Senior Member ste's Avatar
    north dublin
    jeez gem fair fucks to ya would love to have the mechanical knowledge to do some like that.... previous owner will be sick when they see it sliding around
