Results 1 to 6 of 6
    Default elactrical problem s14a
    ok lads my car is as low as it can possibly go and as a result the tire has eaten into the wires above the arch , so first my speedo goes along with the car poping more that usual then handbrake light stays on , then i smell burn so i pop the boot to look at the battery and its so hot its smoking, brought it out to the mechanic and a multimeter test shows the battery reading 18-20v so the altenator is overcharging everything resulting in fuses going in many places
    question 1 - do i need a new altenator or is it overcharging because of the wires that are broke
    question 2 - is it possible the extra voltage has made shit of my ecu???
    any advice will be handy , cheers in advance
    anyone have an idea?
    well the extra voltage would do some harm to the ecu as far as i know, what you running?
    well are the cables broke or worn into????
    its a power fc ecu im worried about loosing the map or even worse doing damage to the ecu itself , ah well there very worn into
    Had same problem best thing is change the loom i tryed fix mine and there was loads of wire's gone and they're so small there hard to work wit i changed the loom best thing you can do.. Every thing should be ok then was for me..
    20 volts on the alenator the diode's are gone lad, that way your battery was warm or hot if you want,
    well i say it could lad damage the ecu,
    rite al lad home,
    rite you want get that alentor fix asap you end up burning everyting out
    bulbs will start blowing coilpack.................
    reason for it there not designed for 20 volts
    get the cables fixed too man
