right so most of you no my bro mark only new to the scean loves it he has a black ps13 at the mo just about finished buliding it, and then ths came up and for the moneys we couldnt walk past it picked it up today still undecided weather to build an engine for it or just pull the freahly built red top from the 13 most likely will keep the 13 log it for pd 2010 and half way in the seson when he has abit more track time done bring this out to play
so a quick spec as it sits:
00 s15 spec r
running gear,
5 speed box
4.3 welded diff
stock brakes
kts coilovers
cusco tension rods
nismo extra lock tie rods and ends
cusco camber arms
cusco traction arms
solid subframe mounts
inside,
full weld in cage
x2 sparco buckets
nardi wheel
x5 defi 60mm gauges oil pres, oil temp, water temp, boost, exhaust temp
defi link controler
autotronics management
hydro hbrake
blitz dsbc boost controler
full fuel system bosch 044 pump swerl pot ect
outside,
+30mm rear overfenders
+30mm vented wings
full orign (style??) aero kit
stock bonnet with aero catches
to be done:
genaral tidy up
build and fit new engine will be red top sr20 on power fc for ease of mapping
head lamp blanks or very cheap lights
pics!!
Ex hankook sponsored car isnt it? Shane healy his name was it? Marini used own it before him..
Never realised it had a z32 box... Way ahead of the game for a few years ago really wasnt it!
