Results 1 to 10 of 18
    Galway
    Default R32 Oil Pressure??
    i have an r32 gts-t, and a few days ago i noticed that the oil pressure gauge was reading high at 8 then i noticed it went to the halfway mark at 4, then i was looking at it and it dropped to 0. Something doesnt seem right...??
    I have to replace the fan/alternator belt because its kinda worn and its screeching like mad, the powersteering went and then the battery died out....so im guessing the belt is f**ked and is slipping??
    any ideas/help greatly appreciated!
    well oil pressure dropping is never a good thing!
    the rest sounds like you just need to change you belts
    Quote Originally Posted by 200sx View Post
    This site is made up off a majority off absolute wank bags,and im sure im one off them from some peoples point off views,all nice fellas in person,but just a bit off a keyboard braveheart.....Thats the way this site is plain and simple,either like it,or sling your hook!!!
    Galway
    Quote Originally Posted by s13-ste View Post
    Sound mate. the gauge reads all over the place sometimes. what would low oil pressure mean?
    well if the gauge is reading all over the place it could be a faulty gauge and not a problem with your oil pressure.
    get an other gauge on there and see if its ok
    Galway
    will do! would an oil gauge be reading all over the place if the belts were slipping? and the battery goin dead?
    i dont see how it could. the pressure gauge wouldn't be anything to do with a belt
    Member
    waterford/kilkenny
    if your were worried about it,we could do an oil pressure check to be sure,and check it out,pm if you like.
    jamie
    085 8894526
    Galway
    sound, well i'l change the belts and take it from there. thanks!
    di Member thegosson's Avatar
    put on power enterprise belts......there awesome
    Galway
    Quote Originally Posted by thegosson View Post
    where would i get them belts mate?
