Mk3 SUPRA 7MGTE
Looking to shift in this supra I have ! Same owner the last 10 years ! Was Drivin on and off for about 3 years then dried stored the rest of the time ! Head gasket was replaced about 3 years ago and torqued to the corrected increased value also had new valve stem oil seals water pump ,Timing belt ,New engine sensors ,Brake pads ,Disk,Shocks and various other things replaced at the time which are all still perfect There was no issue with the original head gasket when replaced it was done as a preventive measure and still have the original gasket and valve stem oil deals to show this along with anything else that's was ever replaced on the car ! All the replaced bits and pieces were kept with the car ! Car has done a 500 miles since then and hasn't been ran in 2 years ! Currently turning over but not firing ,"Fueling problem " hopwfully will have engine running for new buyer ! There's loads of new space gaskets ,Sensors ,brake pads ,Spare parts ,Old Spare parts that are still good ,Original pipes ,Ac compressor ,Ect !
There's also a mountain of printed paper work diagrams in folders for practically every component on the car from engine electronics to mechanics,Steering ,Suspension ,Body ,Ect ..... Car is Shultzed underneath and is rust free as is the body ! Car Is Straight ! Does have a small kink on the drivers door edge wear it meets the wing (Easy Fix ) and does need a respray as the paint work is terrible on it and the seats Repalced or reconditioned as there very shabby and just a general tidy up all round ! Everything is there on the car ! No pieces are missing !
Toyota Supra Mk3 3.0i Turbo
142,000km
7MGTE Engine
5 Speed Manual R154 Gearbox
4 New Shocks And Springs
New Water Pump
New Timing Belt
New Head Gasket
New Valve Stem Oil Seals
New Brake Pads
New Oil Cooler
Cruise Control
Leather Seats (Very Shabby )
Electric Windows Mirrors
Ect ...
€2000
Car Is Located in Waterford
0892371432
